Motor Master Powersports Complete Axle
Motor Master Powersports Complete Axle Assemblies are built to meet or exceed OEM quality. MMPS uses fully assembled outboard and inboard joints installed on a 300m alloy axle bar using the MMPS Dura-Boot for maximum protection against all conditions! Available for Polaris XP1000 and XP Turbo.
REAR XP1000/XP Turbo Technical Details – CLICK HERE TO PURCHASE
- 30% Stronger than Stock
- 300m alloy axle bar
- Includes Dura-Boot for maximum protection against all conditions
- outboard cv joint seal diameter: 1.180
- outboard cv joint spline diameter: 1.120
- outboard cv joint thread size: 18×1.5mm
- number of outboard cv housing splines: 26
- number of inboard cv housing splines: 28
- inboard cv joint spline diameter: 1.200
- inboard cv joint seal diameter: none
FRONT XP1000 Technical Details – CLICK HERE TO PURCHASE
- outboard cv joint seal diameter:1.180
- outboard cv joint spline diameter:1.120
- outboard cv joint thread size:18×1.5mm
- number of outboard cv housing splines:26
- number of inboard cv housing splines:22
FRONT XP TURBO Technical Details – CLICK HERE TO PURCHASE
