2012 Polaris Ranger RZR XP900 (Indy Red)
2012 Polaris RANGER RZR Line Up
Since the introduction of the RANGER RZR 800 in 2008, Polaris has continued to evolve its RANGER RZR line by aggressively launching new models for every
recreational segment. Model year 2009 saw the only-sport RANGER RZR S 800 and 2010 the only 4-seat performance sport Side-by-Side, the RANGER RZR 4 800.
This past January, Polaris upped the ante again with the introduction of the only-Xtreme performance Side-by-Side, the RANGER RZR XP 900. For 2012, the company will make upgrades to the RANGER RZR 800, RANGER RZR S 800, RANGER RZR 4 800 and RANGER RZR XP 900 to make the line even more razor sharp.
The newest member of the RANGER RZR family, the RANGER RZR XP 900, introduced the industry to a whole new class of Side x Side that took the ultimate combination of power, suspension and agility to the extreme. The RANGER RZR XP 900 will continue to offer all of the aspects that make it the most extreme performing Side-by-Side on the market; 900 Twin DOHC Electronic Fuel Injected (EFI) engine, 3-Link Trailing Arm Independent Rear Suspension (IRS) with 13-inches of ground clearance and 14-inches of travel, and a light vehicle weight with a low center of gravity for unmatched cornering with the addition of few upgrades for 2012 to give the unit even more extreme performance. For quick suspension adjustments, the Fox 2.0 shocks feature new, convenient compression adjustment knobs for tool-less tuning. To reduce driveline noise, the unit has a new, rubber isolated prop shaft. For less steering effort and increased maneuverability at slow speeds, Polaris redesigned the front suspension geometry. In the cab, all units feature a new passenger grab bar tube with an anti-rattle bushing for reduced noise.
The Only Trail RANGER RZR 800, Only Sport Performance RANGER RZR S 800 and Only 4-Seat Sport RANGER RZR 4 800 also will see improvements for 2012
including the new grab bar, improved cockpit fit and finish to reduce dust and heat on the operator, a front drive cage made from zinc for added durability, a durable dual clutch inlet for low and high speed cooling, and a 33-percent thicker skid plate. The RANGER RZR 800 also will receive a rubber jounce bumper in the shock assembly for improved durability and the RANGER RZR 4 800 also will feature the improved Fox 2.0 adjustable shocks with compression adjustable knobs.
All RANGER RZRs are available in Indy Red as a standard color, with the RANGER RZR 800 also available in Polaris Pursuit Camo. Limited Edition models include White Lightning with Red Rally Accents, Magnetic Metallic and Boardwalk Blue with electronic power steering for the RANGER RZR 800; White/Orange Madness and Liquid Silver/Red for the RANGER RZR S 800, both featuring Fox Shocks, back by popular demand; White/Orange Madness Robby Gordon with electronic power steering for the RANGER RZR 4 800; and White Lightning and Orange Madness for the RANGER RZR XP 900.
RANGER RZR 800 Key Features
• NEW! Improved fit and finish in cockpit for reduced heat and dust in cab
• NEW! Rubber jounce bumper in shock assembly
• NEW! 33% thicker skid plate
• NEW! Anti-rattle bushing in grab bar
• 800 H.O. EFI Engine
• 0-35 MPH in 3.8 sec.
• 9 in/22.9 cm front travel, 9.5 in/24.1 cm rear travel
• Aggressive front styling
• In-cab glove box
• Easier-to-use side nets
• Only trail capable side-by side at 50 inches wide
• On-Demand True All-wheel drive
• Lowest center of gravity in its class for ground-hugging performance
• Exclusive front & rear sway bars
• Lightest side-by-side at 945 lbs.
• Front & rear dual A-Arm suspension
• Sachs Shocks
• All the utility you need with 300 lb. /136.6 kg Lock & Ride® cargo bed, 1,500 lb. /681.8 kg towing
• ROPS Certified Cab
» Available in Red and Polaris® Pursuit Camo
» Limited Edition models include White Lightning Red Rally, Magnetic Metallic
and Boardwalk Blue with Electronic Power Steering (EPS).
RANGER RZR S 800 Key Features
• In-cab glove box
• Easy to use side nets
• ITP 900 XCT Tires
• Two-inch Big Bore Sachs Shocks
• 800 Polaris H.O. EFI engine
• Pure sport machine at 60 inches wide with 12 inches of long-travel suspension and 12.5 inches of ground clearance
• Chrome-Moly upper front A-Arms for precision and strength
• Front & rear dual A-Arm suspension with rolled independent rear suspension
• Fender flairs
» Available in Indy Red
» White/Orange Madness and Liquid Silver/Red Limited Edition models outfitted with Fox Podium X
Shocks and Maxxis Bighorn tires.
RANGER RZR 4 800 Key Features
• NEW! Clicker Knob on Fox Podium X 2.0 Shocks for tool-less adjustment.
• 60 inches wide with 12 in/30.5 cm of long-travel suspension and 12.5 in/ 29.2 cm of ground clearance
• Lighter than many 2-passenger vehicles at 1,255 lbs/569.3 kg.
• Dual A-Arm front & rear suspension with rolled IRS
• On-Demand True All-Wheel Drive
• Fender Flairs
• Seating for four
• In-cab glove box
• Rear cargo box with 300 lb capacity
» White/Orange Madness Robby Gordon Limited Edition model with Electronic Power Steering (EPS)
RANGER RZR XP 900 Key Features
• NEW! Redesigned front suspension geometry for easier steering
• Polaris ProStar 900 Engine
• 64 in/162.6 cm width with 13.5 in/34.3 cm front travel, 14 in/35.6 cm of rear travel
• 13 in/33 cm ground clearance
• 3-link Trailing arm IRS
• Adjustable Fox® Podium X 2.0 Shocks with Piggyback reserviors
• LED headlights
• Brake calipers and ventilated rotors on all four wheels
• ITP 900 XCT Tires
• In-cab Glove Box
• Easy-to-use side nets
» White Lightning and Orange Madness Limited Edition Models
RANGER RZR 170 Key Features
• NEW! One piece side nets standard
• Youth riders 12-years old or older, Big Wheel Kit available for T-14+ riders
• Big Wheel Kit adds aluminum wheels, larger tires, different drive and driven sprockets plus O-ring chain, skid plate, warning decals and increased ground clearance to 7.5 in/19.1 cm.
• Styled similar to its adult counterpart with a sporty, aggressive look
• Two-passenger
» Available in Indy Red and Polaris NEW! Pursuit Camo
2012 Polaris RANGER Utility Side-by-Sides
The RANGER line, with its flagship RANGER XP 800 model, continues to be the
leading Side-by-Side brand in the world due to hardest working attributes such as powerful engines, On-Demand True All-Wheel drive, monstrous towing and large dump boxes coupled with smoothest riding features such as Independent Rear Suspension, high ground clearance and superior ergonomics.
For Model Year 2012, Polaris continues to build on the success of the RANGER
brand with the addition of the Polaris Engine Braking System (EBS) on the RANGER HD 800 and the introduction of the new RANGER CREW Diesel.
The RANGER HD 800 is the pure utility work horse of the RANGER full-size line
with its self-leveling, Nivomat® rear shocks, Electronic Power Steering and all the attributes that made RANGER the Hardest Working, Smoothest Riding vehicles on the market. For 2012, the RANGER HD 800 brings the addition of Polaris’ Engine Braking System (EBS) to make it work even harder. The Polaris EBS controls downhill braking to give you optimum control and smooth, even deceleration during descents, making carrying large loads even easier. For 2012, the RANGER HD 800 will be available in Sage Green.
Other full-size models offered for 2012 include the RANGER XP 800 in Sage Green, Solar Red and Polaris® Pursuit Camo; the RANGER XP 800 EPS in Sage Green and Solar Red; the RANGER Diesel in Sage Green; and the RANGER 6x6 800 in Sage Green and Solar Red. The RANGER XP 800 Limited Editions include Magnetic Metallic, Pearl White, Boardwalk Blue and the first-ever RANGER XP 800 with a shock package, the RANGER XP 800 Walker Evans edition. The RANGER XP 800
EPS Limited Editions include Sunset Red and Browning Edition Pursuit. In 2011, Polaris entered the diesel Side by Side segment, with the introduction of the new RANGER Diesel. The RANGER Diesel shared the same full-size chassis
as the RANGER XP 800 with the same attributes that made the RANGER line the hardest working, smoothest riding vehicles on the market. For 2012, Polaris is introducing its second diesel model and third vehicle to its multi-passenger line up, the RANGER CREW Diesel.
The RANGER CREW Diesel shares the same 904cc, three-cylinder YANMAR® diesel engine as the RANGER Diesel, with the ability to carry six adults in total comfort. The engine is rubber-mounted to transfer minimal vibration to the operator, and provides low-speed torque to work harder. The fully-sealed, fixed center distance clutch driveline keeps water out of the clutches and provides better performance than competitive models.
RANGER CREW Diesel’s work ethic also includes a 55 amp alternator that gives the operator the ability to run many hard working, higher electrical load accessories, such as plows, extra lights, cab heaters and fans at the same time. It boasts a monstrous one-ton towing to tackle the toughest jobs and comes standard with a 2-inch hitch receiver to tow accessories with ease. Its 1,000 lb/454.5 kg capacity rear dump box has gas-assist dumping operation and accommodates many hardworking PURE Polaris accessories that go on and off in seconds.
RANGER Side-by-Sides are known to be the Smoothest Riding vehicles on the market and the RANGER CREW Diesel is no exception. Its long wheelbase
combined with its fully-adjustable suspension creates a very smooth ride, even when fully-loaded. The vehicle’s suspension is the only four-corner adjustable suspension system that features Dual A-Arms with exclusive top-mounting-point adjustability. For recreational riding, the user can adjust to a softer setting or adjust stiffer for heavy-duty work. With a suspension travel of 9.6 in/24.4 cm up front, 9 in/22.9 cm in the rear and a ground clearance of 11.5 in/29.2 cm, the RANGER CREW Diesel provides a very comfortable ride.
To complement the suspension and travel, the RANGER CREW Diesel features On-Demand True All-Wheel Drive with VersaTrac that keeps you moving, automatically engaging all four wheels when you need more forward traction and reverting back to two-wheel drive when you don’t. When in two-wheel drive, the VersaTrac Turf Mode switch unlocks the rear differential for easier, tighter turns that won’t tear up the grass.
Inside the cab, the vehicle has the ability to carry six adults comfortably due to its superior comfort and ergonomics, including a slide-through cab design for easy entrance and exit that also provides lots of legroom. Leaned seatbacks provide extra comfort during travel and 10-inches/25.4 cm of tilt steering-travel provides plenty of steering wheel position options for the driver.
For 2012, The RANGER CREW Diesel will be available in Sage Green.
Other multi-passenger models not mentioned above include the RANGER CREW
800 in Sage Green, Solar Red and Polaris® Pursuit Camo with EPS and a
Sandstone Limited Edition EPS model, and the RANGER CREW 500 in Sage Green, Solar Red and Polaris® Pursuit Camo, with a RANGER CREW 500 Turbo Silver Limited Edition Model. Polaris will continue to offer the RANGER 500 EFI, RANGER 400 and RANGER EV midsize vehicles for 2012. The RANGER 500 EFI and RANGER 400 will be available in Sage Green, Solar Red and Polaris® Pursuit Camo, with a RANGER 500 EFI Sunset Red Limited Edition Model. The RANGER EV will be available in Boardwalk Blue and Polaris® Pursuit Camo.
More information about Polaris’ whole line of Off-Road Vehicle offerings can be found online at Polaris ATV, RANGER, Snowmobiles, Victory Motorcycles Website.
RANGER XP 800 EFI
Hardest Working Features
• 800 EFI Engine
• High/Low beam headlights
• Full instrumentation
• On-Demand True All-Wheel Drive with Turf Mode
• 1000 lb./453.6 kg box, 1500 lb./680.4 kg total payload
• One ton//907.2 kg towing
• Industry-leading storage
• Removable under-seat storage
• Pallet-size rear dump box with gas assist
• Lock & Ride® Cargo System
Smoothest Riding Features
• Easy-buckle driver and passenger safety nets Adjustable Dual A-Arm
Front Suspension
• Independent Rear Suspension
• 9.6 in/24.5 cm front travel, 9 in/22.9 cm rear travel
• 12 in/30.5 cm Ground Clearance
• Seating for three
• Work-enabling ergonomics including tilt steering, easier steering effort, extra
legroom, and easy cab slide through for three adults to get in and out quickly
» Available in Sage Green, Solar Red and Polaris® Pursuit Camo
» Limited Edition models include Boardwalk Blue, Magnetic Metallic, Walker Evans and Pearl White
RANGER XP 800 EPS
» All the features of the RANGER 800 XP with the addition of Electronic Power Steering (EPS).
» Available in Sage green and Solar Red
» Limited Edition models include Sunset Red and Browning Edition Pursuit
RANGER HD 800 EPS
• 800 EFI Engine
• One ton/907.2 kg towing
• Available Lift & Carry with 500 lb capacity
• NEW! Polaris Exclusive Engine Brakng System (EBS)
• Adjustable Dual A-Arm Front Suspension
• Exclusive Independent Rear Self Leveling Suspension with Nivomat shocks
• Variable assist electronic power steering
• 9.63 in/24.5 cm front travel, 9 in/22.9 cm rear travel
• Seating for three
• Work-enabling ergonomics including tilt steering, easier steering effort and seat back angle
RANGER 6x6 800
• 800 EFI Engine
• Exclusive On-Demand True Six-Wheel Drive
• One ton/907.2 kg payload, 1250 lb./567 kg cargo capacity, 250 lb/113.4 job box
• Heavy duty front end protection, inset lights and the most protection for critical components.
• Gas-assist dump box
• Lockable rear storage boxes hold 39 gallons
• Adjustable Dual A-Arm Front Suspension, middle and rear suspension with motion ratio adjustability
9 in/22.9 cm middle and rear travel
• Seating for three
• Work-enabling ergonomics including tilt steering, easier steering effort, extra legroom, and easy cab slide through for three adults to get in and out quickly
» Available in Sage Green and Solar Red
RANGER Diesel
• 904cc, 3 cylinder, Yanmar® Diesel engine
• 55-amp Alternator
• 1500 lb./680.4 kg total payload
• Pallet-size rear dump box with gas-assist
• Largest fuel tank in class
• Seating for three
RANGER EV
• AC electric motor
• 25 MPH/40.2 km top speed
• On Demand True All-Wheel Drive with Turf Mode
• 500 lb./22.68 kg box, 1000 lb./453.6 kg total payload
• 1250 lb./ 567 kg towing
• Heavy duty front end protection with inset lights and the most protection for critical components.
• High-pressure 20 psi, 25 in/63.5 cm tires
• Rear dump box with gas-assist
• Longest range in class – up to 50 miles!
• 8 in/20.3 cm front travel,
• MacPherson front suspension with Independent Rear Suspension
• 10 in/25.4 cm ground clearance
• Seating for two
» Available in Boardwalk Blue and Pursuit Camo
RANGER CREW 800
• 800 EFI Engine
• 1750 lb./793.8 kg payload, 1000 lb./454 kg cargo capacity, one ton/907.2 kg towing
• Front full-bench under-seat storage and rear under-seat removable storage
• Electronic Power Steering on Pursuit Camo model
• On-Demand, true all-wheel drive
• 11.5 in/29.2 cm Ground Clearance
• Seating for six
• Carries six adults comfortably with leaned seat backs and lots of legroom
• 2 in/5.1 cm more leg room for rear passenger
» Available in Sage Green, Solar Red and Pursuit Camo with EPS
» Sandstone Limited Edition model
New! RANGER CREW diesel
• 904cc, 3 cylinder, Yanmar® Diesel Engine
• 55 amp Alternator
• On Demand AWD
removable storage
• Seating for six
• Carries six adults comfortably with leaned seat-backs and lots of legroom
2012 Polaris ON-ROAD MODELS
For model year 2011, Polaris introduced the Polaris EV LSV as its first civilian Low Speed Vehicle and will continue to offer the vehicle for 2012. Based off the Polaris Midsize Side-by-Side platform, the Polaris EV LSV, includes the necessary features to classify the vehicle as a LSV per the National Highway Traffic Safety Administration, such as a horn, turn signals, automotive-quality windshield, and rear view and driver’s side mirrors. With its 30 horsepower electric motor, quiet operation and 25 mph top speed, the Polaris EV LSV is the most-capable LSV available. The unit features three modes; High for speed, Low for towing and hauling, and Max for maximum range to ensure the best use of power and battery life for any application.
The Polaris EV LSV was built to be tough and reliable. Its 1,000-pound payload capacity, 1,250 lbs. of towing, 500-lb Lock & Ride cargo box, and On-Demand True All-Wheel Drive for harsh terrain makes it the only choice for an electric work partner. Polaris EV LSV also has VersaTrac with one-wheel, rear-wheel drive for a tighter turning radius. Its 48-volt, AC Induction brushless motor provides high performance with low maintenance for maximum reliability. For recharging ease, the unit can be charged using a standard 110 volt AC outlet.
The Polaris EV LSV will be available in Sage Green and may qualify for low-speed vehicle tax credits available to vehicles in the Federal Motor Vehicle Safety Standards (FMVSS) Standard No. 500, Low-Speed Vehicles.
Polaris EV LSV Electric On-Road Operation
Key Features
• 30 HP electric motor
• On-Demand True Alll-Wheel Drive with VersaTrac
• 8 in/20.3 cm front travel, 9 in/22.9 cm rear travel
• 500 lb./22.68 kg box,1000 lb./453.6 kg total payload
• 20 psi, 25in/63.5 cm tires
• Horn, turn signals, automotive-quality windshield and rear view mirror for on-road use as a LSV
• Lock & Ride Cargo System
• Seating for two
