All UTV's Baja Designs – New LP9 8-inch Light 12,000+ Lumens
Baja Designs
Jan 22, 2009
292
15
www.bajadesigns.com
Baja Designs: LP9 8" LED Auxiliary Light
Bailey here with Baja Designs. We are very excited to release the LP9 which is our NEW 8" LED Auxiliary Light. A design that was inspired by Baja Designs’ legendary 8" La Paz HID; The LP9 features modern styling and performance, with some of the most advanced LED technologies available today.
https://www.bajadesigns.com/products/LP9-LED-Auxiliary-Lights.asp
The LP9 utilizes 9 forward projecting LEDS to produce 11,025 Lumens at 105 watts, and 6 LEDs for Integrated Peripheral Technology (IPT) which produce 1,140 lumens at 10.5 watts per side. The IPT provides an incredible 200° spread of usable light.
The housing was designed to provide exceptional heat dispersion by using Direct Ducted Cooling, which allows air to travel from the front of the housing to the rear. With a day-time running light, low, and high power mode, the LP9 will fulfill all your lighting needs.
Available in a standard model that is perfect for a wide range of off-road use, as well as a Racer Edition configuration that is designed for the demands of high speed driving. The Racer Edition has similar power draw, but produces a much tighter pattern, providing higher visibility at greater distances. Both models feature uService technology, which allows customers to change the lens pattern and color depending on driving conditions, or simply when they want to refresh the lens.
LP9, LED Spot (sku 320001) - $539.96
LP9, LED Driving/Combo (sku 320003) - $539.96
LP9, Racer Edition Spot (sku 330001) - $584.96
LP9, LED Spot, Amber (sku 320011) - $548.96
LP9, LED Driving/Combo, Amber (sku 320013) - $548.96
LP9, Racer Edition Spot, Amber (sku 330011) - $593.96
Coupon Code: BDForums
10% OFF + $5 Shipping to the Lower 48!
Thanks Everyone!
-Bailey, Baja Designs
www.bajadesigns.com
Baja Designs
Jan 22, 2009
292
15
www.bajadesigns.com
Thanks for all of the orders! Don't forget we offer a 10% Forum Discount that can be applied to any Baja Designs (BD) product. All you have to do is enter code BDForums
Post up if you have any questions, comments, concerns, or even want to share photos of the BD equipped ride. We'd love to see your setup!
www.bajadesigns.com
Baja Designs
Jan 22, 2009
292
15
www.bajadesigns.com
The LP9 just got a little bit BOLDER!
Introducing a new, more aggressive, cast housing for the LP9. One of the noticeable changes is the larger openings for the Direct Ducted Cooling at the top and bottom of the housing. This will increase airflow to the light and in return keep the light cooler allowing everything to run at peak performance longer. This housing also features a sleek black powder coat finish. Take a look at the website for more pictures and information!
Post up if you have any questions! Don't forget to save nearly $60 per LP9 with your forum discount. Coupon Code: BDForums
www.bajadesigns.com
Baja Designs
Jan 22, 2009
292
15
www.bajadesigns.com
Introducing the LP9 Sport! Available for Pre-Order NOW
The LP9 Sport is perfect for enthusiasts that want the look and features of our successful LP9, but with a little less output intensity and price. The Sport model still includes all of the technology that makes the LP9 series so popular, from Direct Ducted Cooling - that keeps your light cool under stress - to the Integrated Peripheral Technology (IPT), which produces an incredible 200° spread of usable light. The LP9 Sport utilizes 9 forward projecting LEDS to produce 6,500 Lumens at 61 watts, and 6 LEDs for Integrated Peripheral Technology (IPT) which produce 2,550 lumens at 24 watts.
AVAILABLE HERE FOR $459.95
https://www.bajadesigns.com/products/LP9-Sport-LED.asp
Estimated Ship Date - 5/30
www.bajadesigns.com
Pablito2510
