Can-Am CX3 Commander Suspension System
TurnKey UTV
Oct 22, 2010
26
After a year of engineering and testing we are proud to introduce the race proven CX3 Can Am Commander suspension system. We set out to produce the most advanced, highest quality, fully adjustable suspension system on the market and after hundreds of hours of engineering and real world product testing we bring you the CX3 System. Like all TurnKey UTV products the CX3 system is constructed of the highest quality American made materials available. The CX3 Can Am Commander mid travel suspension kit boasts standard features not found on any other kit available including fully TIG welded 4130 chromolly steel boxed arms, fully adjustable front A-arms, delrin bushings, a lifetime warranty on arms and the list goes on. With the installation of the CX3 system to your Commander you will drastically increase the ride quality, stability and handling of your vehicle. This kit increases your wheel travel to 14" and extends the wheel base of your Commander by 4" in turn allowing for higher speeds on rougher terrain. With a wider stance of 6" total or 3" per side you gain vehicle stability on tighter turns while still keeping the added width to a minimum to allow for use in restricted terrain. The CX3 kit also increases the ground clearance on your Commander to 12" giving you that extra clearance needed. The CX3 kit was designed around the Elka shocks to maximize vehicle handling and absorb the roughest terrain. Each kit is individually handmade under our roof by world renowned fabricators to assure the highest quality product available. Kits comes in two standard colors, Commander yellow & satin black. Kit comes complete with everything required for installation including, wider axles, race proven tie rods & all hardware.
Features:
14" wheel travel
6" wider track ( 3" per side )
4" longer wheel base ( 3" rear / 1" front )
4130 boxed steel construction
Adjustable front camber, caster & toe
Delrin bushings
Computer designed & CNC built
Race tested & proven
Made in the USA
Life time warranty on all arms
MSRP: $3,795.00
Link to product:
http://www.turnkeyutv.com/turnkey-parts.html?page=shop.product_details&flypage=flypage.tpl&product_id=102&category_id=47
