All UTV's How the clutch works!!
Discussion in 'UTV Engines, Performance, Maintenance' started by 07fj, Mar 6, 2009.
  1. 07fj
    07fj Rainman - UTVUnderground Approved
    Jan 19, 2009
    Tonopah, Az
    here is some good reading on how our UTV clutches works.
    this shows a dry clutch setup on a snomobile but the principles are the same.
    this is a good example of how the RZR and Teryx work, the rhino with rollers and Cam plate would act similar in reguards to roller weight, but the cam plate is of a fixed angle and not as tuneable as the profile weights in the dry clutch setups, like Bronco or PDM.
    How does the clutch system work? - Gates Snowmobile & ATV Belts
    Rainman
    • Like Like x 3
  2. shonuff
    shonuff "Kiss My Converse" - UTVUnderground Approved
    murrieta
    Re: how does the cltuch work
    great stuff rog!
  3. JoeyD23
    JoeyD23 #utvunderground
    Jan 9, 2009
    North County San Diego
    great post Rog!!! Thanks for hooking us up with some great info!! This is a Sticky Thread!!
  4. 07fj
    Jan 19, 2009
    Tonopah, Az
    just lookin out, you know the rainman can get it done! LOL
  5. JoeyD23
    Jan 9, 2009
    you know I know!!! LOL
  6. az_amsoil
    az_amsoil Amsoil Arizona - UTVUnderground Approved
    Jan 22, 2009
    Rog - I was on Gates site two days go and found that page! Very good stuff...but Gates pissed me off as I have one of their sonic tension meters, but the CVT belts can't be used with it!!! It would make setting the belt so easy...guess I need to dig out my fish scale!:D
  7. AZCourt
    AZCourt AZ's Finest - UTVUnderground Approved
    Feb 11, 2009
    The big difference in the secondary between what I just read and the Rhino is the rhino is not full helix, therefore doesnt have near the torque sensing backshift ability that all others do. Its only helix for the first part of the movement.
  8. 07fj
    Jan 19, 2009
    Tonopah, Az
    yes it is a rotational style with pins in a groove in radiused slots, the effect is similar and torque sensing, but not to the degree that a snomobile helix has.
    but for the basic SxS owner it provides soem good info on what is happening, don't ya think Court??
    Bob, I had this site marked last year when searching for belt replacements, I used to use gates belts in all my snomobiles and had good luck, and was seeing if I could find one for a rhino.
    Rog
  9. AZCourt
    Feb 11, 2009
    Very good description of how the CVT works. I think a full helix type secondary would work a lot better for us, just havent had time to prove it. The pin and slot system works fine, just not sure why the slots start angled and then go straight, thus only torque sensing for the first part of the secondarys travel. Probably to 20mph or so. .
  10. brad.hill.3762
    brad.hill.3762 New Member
    Aug 25, 2015
    is the link bad ?
  11. Jimyz250
    Jimyz250 New Member
    Feb 26, 2018
    Link is bad :-(
  12. JoeyD23
    Jan 9, 2009
    This post was made in 2009 so it looks like Gates may have done away with the og video... too bad..
  13. dkiewicz
    dkiewicz Space Cadet - UTVUnderground's La Familia
    Nov 28, 2009
    Hesperia Ca
    Here's a pretty good stand in for those that want to know...
Share This Page
