here you go the Madigan Motorsports plus 3 per side
4130 boxed kit utilizing stock shock with an added 3'' of wheel travel and the added width for stability that the Maverick needs . The kit includes
front upper and lower arms
front tie rods
Summers Brother plus 3 front axles
rear upper and lower arms
rear radius rod with fk rod ends
Summers Brothers plus 3 rear axles
let us know what u think !!!!! thanks agian
The arms look pretty sanitary. I like the way you slanted the lower leading edge of the front arms to help them deflect possible impacts. Nice touch! The stock rear upper shock mounts on the Mavericks are poorly placed. The lateral loads on the shock shafts are excessive with the forward angle the shocks mount at. Your kit would benefit greatly if you moved the bottom shock mount on the rear arm closer to the front of the arm, and farther outwards towards the tire. You would then need to make an adapter to that attaches to the top shock mount and "twists" the shock eye so it is more squarely mounted relative to the a arm pivot axis., as not to bind the shock.
At the Parker race this season, the Murray's broke both rear shock shafts at the same time while taking a hard impact to the rear of the car. They too, ran the stock mounting angle of the rear shocks, and were running 5/8" shafts. They beefed up the shafts to 7/8" of an inch, and have had no further issues to my knowledge. Because the shock does not pivot perpindicular to the a arm pivot axis, there is a side load being introduced into the shock shaft as it compresses. This is just one of many problems that arise when designing a consumer friendly bolt on kit for the general public, but it doesn't have to exist. These fundamental flaws can be addressed, and alleviated through creative minds like ours.
Good luck with your kits, and remember, there is always room for improvement, even if you design F-1 cars! Great job !
