Yamaha R1 Engine Swap - Keep 4x4!!!
Discussion in 'UTV Engines, Performance, Maintenance' started by 4X4 R1-Rhino, Jan 18, 2009.
  1. 4X4 R1-Rhino
    4X4 R1-Rhino New Member
    Jan 16, 2009
    washington state
    As some of you may know, there are a few Rhino owners that have upgraded the engine to a streebike-powered set-up. So far, theve all been built into 2wd setups. I elected to retain 4X4 on my Rhino and upgrade the engine as well.
    I have a 2004 Rhino that I installed a 2004 Yamaha YZF1000 R1 engine into.
    These engines produce approx 180HP in stock form! I was able keep the stock Rhino 4wd functions by utilizing a small gearbox, modifying it slightly for use as a transfer case...The new 4130 chromealloy drivelines pass completely through the gearbox; and then connect to the front and rear diffs. Im still using the stock diffs and axles for the time being. I used stock Rhino u-joints through-out and was able to get some different yokes for the driveline from a yamaha shaft drive motorcycle (they use the same u-joint).:rolleyes:
    From the output shaft on the engine(where the sprocket normally is) I had a coupler machined with a flanged yoke, u-joint, and a sleave machined to fit the gearbox's input shaft...;)
    So the setup is ALL shaft drive...NO CHAINS:D
    The cool little gearbox has HI and Low ranges AND reverse.
    Each of the motorcycle engines 6 gears can be used in any of the ranges or reverse. LOW RANGE, 1st gear is very low and slow, with idle speed of only 2MPH! (like low,lo in a 4x4 truck or jeep).... In high range and in 6th gear the top speed is nearly 100MPH on 29" tires!
    This design gives you the best of both worlds, 4x4 and POWER without sacrificeing much in the process...:eek:
    Another cool thing is the clutch; ( I added a pedal on the floor) much more engine braking the the stock cvt system, more controll over the engine as well.
    Another nifty thing is that I have all the gears/ranges avaliable from ONE shift knob....Its really slick.
    Check out the vids.
    [ame="http://www.youtube.com/watch?v=A11ZpBxwTkY"]YouTube - rhino shifter[/ame]
    Allan
  2. JoeyD23
    JoeyD23 #utvunderground
    Jan 9, 2009
    North County San Diego
    Thanks for posting! This is a very interesting topic. Retaining the 4x4 with the R1 is a sweet deal!!
  3. 4X4 R1-Rhino
    Jan 16, 2009
    washington state
    Heres a few more pics...
    Allan
  4. Mush
    Mush Food Stamp Ninja - UTVUnderground Approved
    Jan 16, 2009
    Hendertucky NV
    do you have problems with the cables on your shifter stretchin or coming outta adjustment?
  5. 4X4 R1-Rhino
    Jan 16, 2009
    washington state
    No problems yet:D and I was able to use the stock R1 motorcycles' throttle cables for the shifter, so the parts are easily located and replaced if something breaks or wears out.:cool::rolleyes:
  6. DSD
    DSD Dirty Side Down - UTVUnderground Approved
    Surprise
    How about a gear box without the 2 ranges? With the exception of the super low and super high, most of the gears would be over lapping anyway?
  7. 4X4 R1-Rhino
    Jan 16, 2009
    washington state
    Heres the problem with that....in a steetbike engine, the gear ratios are very close together,:rolleyes: so you would have to compromise either top end speed or low speed crawling, with only one gearbox "range" ratio:mad:...My setup allows both low end grunt and high top speeds depending on which range its in.;)
  8. DSD
    Surprise
    I know, I would rather have the high end than stunp pulling low end. What does it pull like if you start off in the high range? It still has to be a whole lot better than a single cylinder 660 or 700!
  9. 4X4 R1-Rhino
    Jan 16, 2009
    washington state
    Hers a pic of the gearbox....
  10. rhino 660
    rhino 660 New Member
    Jan 20, 2009
    that thing is awsome do u have any vids of u in 4X4 in some slickness and spinning all 4
  11. 07fj
    07fj Rainman - UTVUnderground Approved
    Jan 19, 2009
    Tonopah, Az
    I still think who ever sells those, would sell more if the UTV peeps knew who the Mfr was! :eek:
  12. DSD
    Surprise
    Maybe they only wanted to sell one of them? lol
  13. 4X4 R1-Rhino
    Jan 16, 2009
    washington state
    Again, please realize this thread is not about selling gearboxs, but rather to show that there IS a way to keep 4X4 AND still have R1 power.:D
  14. 1300vtwin
    1300vtwin New Member
    Jan 17, 2009
    wow who built that cage and susp.? what wheel package are you running?
  15. 4X4 R1-Rhino
    Jan 16, 2009
    washington state
    Stock, like the pics show....if and when I do a Long Travel system, it will be posted over in the suspension section.
    Next month I will be running Super Swamper TSL (29x8.50x15)
  16. little bandit
    little bandit New Member
    Sep 26, 2009
    Who is the manufacturer of that gearbox? What did you get it out of?
  17. dnf736
    dnf736 Retired - And Still UTVUNderground Approved!!!!
    Alpine, CA
    Divorced T-case box, there are a few different makes out there.
    Pretty sure I know what thats out of and its not what you think, his secert though, Ill let him tell you.
  18. megadesertdiesel
    megadesertdiesel Well-Known Member
    Jan 25, 2009
    Mesa, AZ
    looks like something out of a tractor
  19. You HAVE TO BE KIDDING ME!! 1000cc over 100 hp and 4x4 !!!! I know what my next mud bogger project is!!! Nice write up!! Thanks!
  20. Wild Earp
    Wild Earp 50Fifty Racer - UTVUnderground Approved
    Jan 22, 2009
    Southern California
    The transmission is out of a Skidoo. Its got F, N, R, High and Low. He makes the shaft to convert it to 4wd. He posted the info somewhere. You can get the tranny for about 1700 new online.
Share This Page
