Yamaha Top speed?
littlegrande
Little Grande
Nov 4, 2013
16
My 660 tops out at 64 MPH
45mm hsr mikuni Carb
Trinity dual exhaust
Has had engine work (previous owner. Don't know what)
So what does yours top out safely at?
Sent from my C5170 using Tapatalk
littlegrande
Little Grande
Nov 4, 2013
16
64 is moving for a Rhino 660!
Nate
Alba Racing
The Carb and exhaust are the only visible thing that I can see on it. Don't want to take the head off just to measure the cylinder. I don't ride with anyone to get a base to compare to :/
paulk
Jun 11, 2013
Peoria, Az
my 06 686 was right at 62 on GPS
like said,, 64 is very good for the rhino
if that's from the speedo, they usually clock a little fast
littlegrande
Little Grande
Nov 4, 2013
16
If you are doing 64, then it likely will have head work, piston and cam and a clutch sheave. It probably is a 686.
Speedo doesn't work, measured it on the GPS. I'm sure it would go faster but I ran out of road
Timberdog
Aug 23, 2010
You definitely have motor work. I had an '08 with an MSD and greaseless weights and barely broke 50 on the gps.
Bumpers
Jan 23, 2012
190
5
Mine has been 63 with my 720 .. its got more left but maybe 1-2mph but i get scared holdin it down that long cause she's singin at those speeds
OMC
60mph
check out my Rhino Getin Wet
<iframe width="640" height="360" src="//www.youtube.com/embed/ay9vC2v6ayM" frameborder="0" allowfullscreen></iframe>
Bart
UTVUnderground Approved
Dec 10, 2012
47
Canyon Lake, Ca.
My 660 stock motor, hot rod greaseless, black rhino cdi, muzzy exhaust, uni filter, and bed delete....does 59 on the dash, gps says 61...not sure which is correct, so i go with 60mph...but if you ask any of my friends "not fast enough"...LOL
thekevin
Mar 23, 2013
Mine would hit 64 before the piston and cam swap. This video is with my daughter in there with me and me trying to film the gps. With my 26" tires the dash showed 62 and the gps read 64.
<iframe src="//www.youtube.com/embed/ODg-IcCkdmA" allowfullscreen="" frameborder="0" height="315" width="560"></iframe>
This is after my 11:1 piston and Stage3 cam. It would hit the rev limiter at 61mph but get there much faster.
<iframe width="560" height="315" src="//www.youtube.com/embed/QKrvmhvhyxM" frameborder="0" allowfullscreen></iframe>
sand shark
Mar 30, 2009
1,867
256
West Hills, CA
That is very impressive. Was that on a paved road?
My rhino before my motor work with just a carb, sheave and black rhino cdi would hit 50 to 53 on a flat dirt road. Any of the 660 rhinos I have been with do not see mid/upper 50s or low 60s without motor work.
The JBS sheave must allow the belt to really ride high and get more top speed.
Bart
Dec 10, 2012
47
Canyon Lake, Ca.
it was on a flat dirt road...i havent been able to do a paved road run...i bought this rhino the way it is, the guy i bought it from says the motor is stock...he seemed truthful and the rhino was VERY well taken care of, with receipts for oil changes and regular maintenance....everyone that has been in it, have been surprised, and most of my friends think its got a 686 and im just BS'ing them...but in reality, i was just told it was stock...so who knows?...
OMC
<iframe width="560" height="315" src="//www.youtube.com/embed/yrFeJIw4X48" frameborder="0" allowfullscreen></iframe>
sand shark
Mar 30, 2009
1,867
256
West Hills, CA
I bet your motor has work done to it. Either way that is moving in a rhino.
