After testing the stock X3 one of the handling characteristics we wanted to improve was the front sway bar. With the factory bar we found it very easy to enter into a corner at speed and dive the nose of the car down onto the front outside tire which picks up the inside rear tire and slows you down. This uneasy feeling can be unsettling and is a huge limiting factor to corner speeds. The key to fixing this is a front sway bar with a higher spring rate that limits the roll over and dive in the corner. With this in mind, we designed our front way bar system with a larger diameter, heat treated bar, stronger bushings and billet bushing clamps as well as a bulletproof set of sway bar links to handle the extra load our stronger bar can provide. Through our testing we found that the stock bushings, bushing clamps and links were not strong enough to hold a higher spring rate bar needed for adjust ability. For this reason we supply all of these parts in the kit so there will never be a failure.
The most important feature of our sway bar system is it's unmatched adjust ability. With three holes to use you can tune our front bar system to YOUR driving style and terrain. Slow mountain trails? No problem, set our bar on the most compliant setting. Fast dunes, aggressive desert racing? No problem, you can set the bar on the stiffer setting. No matter what your driving style is or the terrain you run our front sway bar system can be tuned to fit your needs and improve your stability.
We have over 200 in stock and they can ship same day. Complete kit cost is $549.95. Forum discount of 5% brings it down to $522.45. Here are some pictures and our installation video if you would like to see how it installs. If not skip to the end, the bloopers are fun.
