2013 Teryx 750 knocking HELP
chriedwa
55
New to the forum and need help. My teryx sat up for nearly a year with very occasional use. Have been using it for nearly a month now. Went to crank it the other day and it took forever. I heard a slight knocking sound so I turned it off and checked oil. It was low. I put about half a quart and started it again. Knocking again and as I tried to listen for location of noise it started to smoke from the engine. I turned it off immediately and have been researching ever since.
I'm not very mechanical at all but I'm not scared to try anything. I've seen posts that talk about rod bearings and belts. It would be nice if it was a belt issue because the rod issue sounds expensive.
Additionally, I really have no clue. I need all the help I can get. Thanks in advance.
