Who has the most ply's in sidewall? I've ran three different brands and having problems with all I have owned.
Have you run the original Maxxis BigHorns? Not the 2.0's.....I never had a sidewall issue with the BigHorns, and I want to say they are a six-ply sidewall.Who has the most ply's in sidewall? I've ran three different brands and having problems with all I have owned.
Might need to try the KM2 on a 15" wheel, the tire is thick and great in rocks and desert, not so much in any sand.... Mongrels haven't had good luck. Dirt Commanders no luck. Itp Baja cross no luck. Never been a fan of big horns. I wonder if it could be the tire size I'm running? I'm running 27x9x14 all the way around. Mack 90 is running 26x9x12 and having the same problems.
Are the original big horns bias ply? My local tire guy says bias tire has a lot stronger sidewall they just ride like poo!Have you run the original Maxxis BigHorns? Not the 2.0's.....I never had a sidewall issue with the BigHorns, and I want to say they are a six-ply sidewall.
What is a good air pressure for dezert? I have my 1st race is cal city April 20th 200 miles hoping to make my tires last.Is it possible it is an air pressure issue? I know if your running low air pressure you will end up with Pinch Flats.
15 pounds is probably fine, I have just seen people trying to run low pressure and end up with pinch flatsWhat is a good air pressure for dezert? I have my 1st race is cal city April 20th 200 miles hoping to make my tires last.
Thats not necessarly true, we had tire balls, they sucked. we took them out and threw them in the trashTIRE BALLS = NO FLATS
Thanks15 pounds is probably fine, I have just seen people trying to run low pressure and end up with pinch flats
I just got a tusk hd tire 26x9-12 for a spare. Looks really nice but it's smaller then a 26 it's measures like 24 1/2-25 why is that if the side wall says 26?First I have good luck with Tusk tires very good side wall protection.
I do mostly trail ridding air psi. 10 in front 15 in rear.
Hope this helped some of you.
