FEATURE PRODUCT: HCR TERYX LONG TRAVEL
HCR RACING 2016 KAWASAKI LONG TRAVEL KIT
Also Compatible With 2nd Gen T-2 & T-4 Models (2012-CURRENT)
HCR Racing is reviving the reliable Teryx for 2016. With an added 3.5“ of wheelbase, the Teryx can now run 32” tires and slide over obstacles in style.
TRAVEL & DESIGN
4130Heat-treated, billet balljoint receivers are used instead of tubing for added strength and multiple weld points; eliminating a potential weak point on the Arm. A J-arm mounting style of the lower shock allows for longer stroke shocks and more travel. This +5″ kit adds 10” of overall track width and 3.5” inches of wheel base for better handling, stability and overall performance. Additional clearance has been added to front and rear arms. Achieve overall performance gains with 15+ inches of travel on all four corners; almost double compared to factory 8” of travel. Approach angles have been re-designed into the catacomb boxed arms for less surface attraction and friction.
MATERIAL
The 2016 T-4 Kit has been designed with the HCR eliteMaterial, enabling kits to be 25% lighter than initial design. This custom alloy is 30% stronger in yield and tensile strength than 4130 Series Chromoly and hardened for wear resistance. HCR took the indestructible to the next level allowing pocketing and material removal without reducing strength. All kits are fiber laser cut and CNC bent for accuracy and precise fit and finish. Each arm is hand TIG welded by seasoned craftsmen for strength and aesthetics.
SHOCK PACKAGE
HCR Race series Kings are included with every HCR T-4 Kit. These shocks include King’s wide range compression adjusters standard. Allowing up to 30% adjustment providing the ability to precisely adjust compression from super soft to super firm with the simple twist of a knob. The clearly marked knob offers 20 positive clicks of finely tuned adjustment. You can soften your ride when just cruising or firm up the compression when hammering rough terrain or carrying additional payload. You’ll have the ultimate in performance regardless of your pursuit.
* complete kit includes: 4 front arms, 4 rear A-Arms shocks, axles & needed hardware
AXLES
RCV axles are now included with everyKawasaki T-4 kit. HCR has been working closely with RCV to provide the strongest axle options on the market; boasting twice the strength of a Factory axle and featuring rolled splines compared to the standard cut spline. RCV’s Revolutionary axle shaft design provides the strength,smoothness, and reliability you need to power through the most demanding off-road conditions.
FEATURES
+5” Over kit adding 10” of overall track width
15” of travel
3.5” of added wheelbase; enabling use of a 32” tire
Manufactured with HCR Elite Material. This Custom Alloy Boasts 30% stronger tensile & yield strength compared to 4130 series Chromoly.
Custom Valved King HCR Pure Race Series Shocks.
Laser Cut construction for precise fit and finish
CNC 4130 billet mounting points for increased integrity
RCV Axles 4340 Series Chromoly
Added ground clearance to front and rear arms
Compression Adjusters allowing 30% adjustment for all terrains and driving styles.
High Clearance Boxed A-Arm Design providing increased ground clearance and strength
Each piece is hand tig welded for strength and aesthetics
OEM balljoints to maximize low speed steering, ease & smooth travel with less maintenance
100% Bolt-on installation using factory mounting points
Part #: TER-05400
MSRP:$4,999
LEARN MORE HERE
CONTACT INFO
[www.hcrracing.com] [630 N. 800 W. Cedar City, UT 84721] [[email protected]]
[Toll Free:888-928-7223] [435-865-9280]
All kits run 3-5 week production time and are custom built to order. If you are trying to make an event, please call 435-865-9280 and we will accommodate best possible.
