All UTV's motorcycle engine
pontiac
Hello!
I want to build a utv long travel with motorcycle engine with a power above 85hp. I want to ask if this such a motor can be installed gearbox with reverse gear (
from ATV or other vehicle) ? I'm going to use this vehicle for long travel. What engine and gearboxes should I use ?
Thanks Adam
Wild Earp
You can use most any motor you want. Popular choices are Yamaha R1 and Hayabusas. DarkSideFab makes a kit that used the RPM reverse box, and a R1, bolt in for a Rhino.
What UTV are you starting with?
The big $$ item with the street bike swap is the Reverse box. They range from $2500 to $3500.
