Hey Guys Skat-Trak has been working on this one for a while now and Came up with a new Tire that starts life out as a 4 ply tire.
Here are the specs for the 30" tire Skat-Trak made for me The casing 30x14* they installed 9 Extreme paddles on it.* The tire weight was 17lbs The wheel weight is 11lbs.* The tire and wheel mounted weighed 28lbs. The roll out with 10 lbs of air pressure was 90" exactly measuring The height of the tire from the floor measured 28 1/2" tall.** Ouch* thats huge my Tire is 2lbs heavier with the Rim than a STU. WOW!!!* especially when you add it up.* Every one here can probably agree that the STUs have a lot of excess* Rotating mass and unsprung weight hanging out there Correct.* So what tire and wheel combination will Accelerate faster* and handle better.** That being said, you argue that the heavy 4 ply STUs are better for dunning how is that when a lighter tire combo accelerates faster and runs higher speeds.* You say what?** The Skat lays over and doesn't get the traction.* Really!** If they laid over that far they would come off the beads.* The only time i see tire off the beads is after a crash. So for Dune riding I don't see the need for a bead lock wheel.
I stopped by Skat-Trak on Thursday and they had a nice looking STI wheel 14" that weighed in at 12 I think so that's not to bad for a good looking wheel. but not as light as the Spun Wheels. I see the 50 Caliber Bead locks Weigh in pretty damn light to. so there's a few good choices out there.
Im going refer you to call Tim Kelly at Extreme Tire in Phoenix Az at 602-576-1043
