Rigid Industries :: D-Series :: Dually & D2
RigidIndustries
12
We often here these referred to as the gateway light... it's where the obsession with turning night into day begins! :D
Big Power in a Small Package
The Rigid Industries D-Series LED Light is one of the most versatile lighting products on the market today. It produces extremely high output while consuming very little power. Its compact size and shape allows it to fit almost anywhere and be used for virtually any lighting application.
Torture Tested & Approved
Watch the making of our D-Series after we hit a record number in production, right here in Arizona!
Dually or D2? The difference is what's inside:
The Dually uses our Hybrid Optics System in a 4-LED configuration which comes in either Spot or Flood options. It produces 1,568 lumens at only 15.8 watts and 1.1 amps. To put that in perspective, it uses less power than it takes to use your turn signal.
The D2 has 6 LED's that utilize our Specter Optics System, which comes in either Driving or Wide configurations. It produces 3,096 lumens and uses only 34.5 watts and 2.5 amps. The D2, with it's driving beam, produces the perfect combination of distance and width for lighting up the road or water in front of you.
Our new Hyperspot optics are also part of the Specter family and produce 1760 RAW lumens with a peak beam intensity of 93000 cd. The highest intensity per watt or square inch on the market as well as Maximum Distance!
Why Rigid:
So what are you, or did you start with?
The Dually or the D2
Share the photos of your D-Series with us!
megadesertdiesel
Jan 25, 2009
1,838
73
Mesa, AZ
i love behind the scene videos. How many dually lights have been sold, ever? Did you keep the first set ever made? I drive by your shop every day to/from work and your parking lot is jamm packed with employe cars. Looks like business is doing really well. congrats.
