Welcome to our new How-to video series from UTVUnderground where the pro’s show you how easy it is to do-it-yourself and fix your UTV.
UTV’s are amazingly low maintenance machines, but every once in a while you will have a mechanical failure and broken belts are definitely one of them. With the correct tools, you’ll see how simple the process is. Multi-time Baja 1000 winner and factory Polaris RZR racer Mike Cafro shows you how to replace the belt on your Polaris RZR. Watch as Mike breaks down the tools you will need as well as an easy to follow step by step guide on swapping out your belt, but like most routine maintenance, it’s always best to practice at home first. You wouldn’t want to attempt this albeit simple task for the first time, deep in the trails. For this How-to video we went with a Gates G-Force Redline CVT Belt. Check out the full line of Gates belts at www.gates.com/redline. To find the proper belt for an application, reference the Gates online catalog system at navigates.gates.com.
