2013 Can Am Maverick HCR Long Travel Release
Ignore Amos
422
32
Tucson, AZ
HCR RACING, the first in the industry to release the new Long Travel suspension for the 2013 Can Am Maverick. After countless hours of research and development, HCR is proud to showcase the newest line in our fleet of performance products at the 2013 King of the Hammers race event. Come on down and check us out!
2013 Can Am Maverick Specs:
4" Wider Per Side = 8" Wider Overall
Will still fit in a toy hauler under 70" wide
2†forward, 1†rear = 3†longer wheel base for more stability and better handling
Added ground clearance without raising overall height under key components
2.5 King Racing shocks standard with HCR Kit
Compression adjusters standard with 30% adjustment
Summers bros 4340 axles
18+" of travel
100% Made in the USA
Hand Tig Welded for strength and appearance
Uses Stock ball joints to increase low speed steering and travel
CNC bent for repeatability
Chromalloy mount points for strength
Check us out at HCR Racing, LLC
NIKAL
May 13, 2012
970
310
So how does a 64 inch wide machine with a plus 4 on each side stay under 70 inches wide? Just curious
Oops! Maybe their math is different then everyone else? If so I wonder how much wheel travel they are really getting, using our math?
