All UTV's cvt belt help
07fj
Jan 19, 2009
1,383
25
59
Tonopah, Az
what clutch? what brand of belts? cvt tube filter or none?
get stuck alot? how are you using your rhino?
yamaha OEM belts are the best, then EPI severe duty only.
mike77
5
the thing is completly stock including the belt, found no burrs on the sheave pretty much only take it to glamis and only on sand highway.
c&c rhino
Jan 18, 2009
351
11
lake elsinore, ca
only new belts ive broken are aftermarket belts i didnt put through a break in cycle. all belts should go through a break in cycle before wide open running.
tech3sandcars
Tech3 Sandcars
Mar 10, 2009
174
59
Oregon
www.tech3sandcars.com
Is the driven sheave actually moving. Some kawa's had a problem where the secondary was not opening and causing the belt to cock sideways, may need to run without the cover on and watch. Any burnt rubber smell?
07fj
Jan 19, 2009
1,383
25
59
Tonopah, Az
since you have not answered some of the ??. since your first belt blew, you may have a roller out of place, causing this. take the primary off and inspect and regrease it. install a new yami belt.
Goodtimes
Jan 17, 2009
1,411
42
Ramona
Nice one Rog
mike77
5
thanks gonna use a stock belt had to replace weights does anyone know how much grease to use? casing had grease everywhere could this be a problem?
