CBR Performance Products, Inc. has released its new KAWASAKI TERYX 750 STAGE 2 COOLING KIT. This kit features the latest and greatest in high performance cooling technology. This kit earns the title “the ultimate cooling package†for its revolutionary radiator core and oil cooler system. The core features a 6.6mm fin height, 42mm thickness, triple pass and oven brazed core. This allows a larger surface area for an efficient cooling process, including a 20% coolant capacity gain. Compared to the stock radiator design, a 10mm fin height, 26mm thickness, and single pass. The kit also includes a 900 CFM Spal high output fan and custom shroud. The oil cooler system features a unique internal turbulized fin design that improves the flow of oil more efficiently and benefits from its low pressure drop design configuration. A new oil filter relocation bracket allows for larger oil filter, easy oil changes and 15% gain in oil capacity. Temperatures have dropped up to 40 degrees with this kit in the most extreme and brutal driving conditions. This kit is 100% aluminum and features aircraft quality design and welding. Kit includes radiator assembly, oil cooler assembly, and all brackets and hardware to install the kit.
