Yamaha New Rhino 700 Hotcams
KJSmith84
Banned Por Vida
516
10
39
somewhere up my own ...
I know this question will be brought up about the "new rhino cams" so let me just post the info so everyone knows that there is NO new cam that was designed for the Rhino 700.
the Rhino and Raptor stage 3 are the same cam.
the Rhino stage 2 is a Raptor stage 1 cam.
The Grizzly stage 2 is the same as the Raptor and rhino stage 3
The Grizzly stage 1 is the same as the Raptor 2
The Grizzly Mud buster is the same as Raptor stage 1 and the Rhino stage two.
So as you can see there are three different cams.- no new cams.
so lets say cams A, B, and C
Cam A - Raptor stage 1, Grizzly Mud busters, Rhino Stage 2
Cam B - Raptor stage 2, Grizzly stage 1
Cam C - Raptor stage 3, Grizzly stage 2, Rhino stage 3
Camshafts 4064-1 Yamaha Raptor 700 2006-2007
Intake lift (mm): 9.60
Intake lobe center (degrees): 111.75
Intake duration (degrees at 1mm): 253.50
Intake valve lash (mm): 0.10
Exhaust
Exhaust lift (mm): 8.60
Exhaust lobe center (degrees): 102.00
Exhaust duration (degrees at 1mm): 243.00
Exhaust valve lash (mm): 0.18
Note: Divide mm values by 25.4 for inches.
Camshafts 4065-2 Yamaha Raptor 700 2006-2007
Intake lift (mm): 10.30
Intake lobe center (degrees): 111.00
Intake duration (degrees at 1mm): 260.00
Exhaust
Exhaust lobe center (degrees): 102.50
Camshafts 4091-3 Yamaha Raptor 700 2006-2007
Intake lobe center (degrees): 112.50
Intake duration (degrees at 1mm): 268.00
Exhaust
Exhaust duration (degrees at 1mm): 255.00
Camshafts 4129-2 Yamaha 700 RHINO 2008-2009
Exhaust
Camshafts 4130-3 Yamaha 700 RHINO 2008-2009
Exhaust
Camshafts 4126-M Yamaha 700 GRIZZLY 2007-2009
Exhaust
Camshafts 4127-1 Yamaha 700 GRIZZLY 2007-2009
Exhaust
Camshafts 4128-2 Yamaha 700 GRIZZLY 2007-2009
Exhaust
Reactions: 1 person
