2013+ Polaris Ranger XP 900 OE Replacement Needle Shocks
High quality performance shocks play a big part in the control you have while driving your UTV through tight trails, in the woods, or up and over sand dunes. Walker Evans Racing compression adjustable piggy back coil over shocks are a great way to improve the over all ride quality and handling on your Polaris Ranger XP 900 UTV Side x Side. Our shocks come standard with a 16 way adjustable compression feature which allows you to fine tune your 2013 Ranger XP 900 no matter what terain you are faced with. This feature with our factory tuned valving will help you soak up the terrain and improve over all stability. Optional spring rates available to accomodate added acessories or specific specific driving conditions.
Available Shocks:
Part Number Description List Price
903-16-522 6" CA 16 Needle Piggy Back Reservoir - Front with Spring $468.99
900-16-523 6" CA 16 Needle Remote Reservoir - Rear with Spring $468.99
Features:
MADE IN THE USA
RE-VALVABLE AND RE-BUILDABLE
16 WAY COMPRESSION ADJUSTABLE RESERVOIR
5/8" MICRO-ALLOY STEEL NITRID COATED SHOCK SHAFTS
ANODIZED FOR PROTECTION AND LONG LIFE
BILLET ALUMINUM DESIGN
2" D.O.M STEEL SHOCK BODY
1/2" STEEL BEARING SHOCK ENDS STANDARD
BILLET REAR RESERVOIR MOUNTS
DESIGNED TO FIT IN OEM MOUNTS
QUALITY FIT, FUNCTION, AND APPEARANCE
Notes:
This shock is for use with OEM arms only, or long travel kits where the shock mounts are in the OEM locations
