Take a look and see what you think.
http://stadiumsupertrucks.com/sst/rules/rules-for-quads-side-x-sides/
It says Computer can be modified, but must use OEM computer. I dont see where if you have 5 more HP you will be DQ'ed. I bet dyno'ing is to keep those from doing engine mods and making big power. Playing with the computer and clutches is not going to make big HP like bore kits, cams and other internal engine mods.Those are not very professional rules! Mods are allowed, but dyno checked after the race?? So if I spend hundreds of hours dialing in my clutches and ecu and exh system, and I make 5 more hp than the guy in second I get DQ'd?? That is pretty amateur. So whats the HP limit??
They got some work to do!!
I'm wondering if they should not have used the work Head & Neck device vs Hans Device. Unless they are truly mandating Hans only? If you use something besides the Hans Device you should contact USAC and ask if the H&N you use would be an approved H&N. I know several who use the R3 & Defender H&N and both of those are approved by most series.so i have to wear a hans device rather than a competitors restraint system?
Thank You
We don't have any Manufactures committed yet but we will.
Also there will have Main Event motos on our TV both cable and Network.
Speed Energy
Robby Gordon
Thanks for the prompt reply Robby!
Last question:
What does a USAC License consist of? Cost?
Thanks again!
........I have been in contact with USAC today and don't have that exact cost yet.
Also I'm leaving the country for Baja for 2 weeks, the replys will be less responsive but people are checking [email protected]
Thanks
Sorry
Speed Energy
Robby Gordon
Brian, Have you heard how the RG vs Polaris lawsuit is going?Wanna race your SR1's in first gear only? These courses will be quite shorter, and tighter than your typical LOORRS short course.
Its my understanding that Can-Am is registered already and I would imagine Polaris will follow suit.
Think UTV's will just be a side show? Think they'll get any air time?
I have no idea. Certainly could affect Polaris involvement.
What was the lawsuit about?
I understand your concern and will say that I'd rather have the mounting surface fail prior to the cage surrounding me..120 wall cages? Come on. Does any body notice what we are bolting too? Hopefully they re consider.
