How many others have had this bearing go bad in the transmission? This is the 3rd one I have seen in person from friends I ride with. The other 2 were turbo'ed one had almost 4000 miles the other had about 1400. This pic is of my 2012 xp4 with 1475 miles and is completely stock. I have doubled all the service intervals so I believe the oil was changed 2 times since I have owned it. I have seen several others online. Is this a common failure in the desert races? We mostly dune. There are allot of info on changing the Chinese bearings to higher quality Japanese bearings and I'm thinking I'm going to have to do this in both of my xp's, that's after I buys a new transmission for 2000 bux.
In the pic you can see how it popped thru the case. I had to drive in reverse through the dunes from flag pole to the bottom of Olds so they could tow me. All with no oil and grinding the whole time. It's hard work duning in reverse.
