11' RZR S problems
VBosch02
Dec 3, 2010
522
Bellflower, Ca
Anyone having problems with there 2011 rzr s motor turning off while driving? I can run for about 15 to 20 min before the motor will sputter and then turn off. It will take a couple of cranks and then start up but the check engine light comes on. Then it will run like crap for a few min check engine light turns off and runs great for a little while again. The only mod I have done is an UMP intake system. Didn't have any problems with the car until I put it on. Is this the problem or is it coincidence? Motor oil and radiator fluid are fine checked that several times. Thanks for any help or ideas. :confused:
v8jeep86
60
well its causing a lean problem maybe causing it to over heat it needs more fuel when you add more air
v8jeep86
60
you will have to find a fuel controler to add more fuel , this is the problem with manufactures they build somthing and do it half assed and not include a fuel controler or a map for a good controler , i have a terys and i program my own maps for mine works great 68 mph with a 750 teryx with bolt ons and my own intake system
07fj
Jan 19, 2009
1,383
25
59
Tonopah, Az
I dobt it is lean enough to cause issues and shut down with a paper UMP, they do not flow much, ( clean but not more flow) and if it was lean it would still restart right away.
sounds like a dirty fuel filter to me, or a sensor that is getting hot and causing the "check engine light" to come on.
what temps are you running when it quits?
