NEW 2011 RANGER RZR XP 900
18,569
1,368
113
North County San Diego
www.utvunderground.com
The NEW Polaris RZR XP 900
RANGER RZR Introduces a Whole New Class of Side x Side
RANGER RZR XP 900 Offers Razor Sharp Xtreme Performance​
To ring in the New Year, the RANGER RZR family welcomes a whole new class of Side x Side, introducing the RANGER RZR XP 900!
The RANGER RZR has the only family of Sport Side x Sides with Razor Sharp Performance for all types of recreation. It all started in 2008 when Polaris introduced the only trail-capable Side x Side, the RANGER RZR 800. In 2009, came the only true-sport Side x Side, the RANGER RZR S 800. With the introduction of the RANGER RZR 4 800 in 2010, Polaris introduced the world’s only four-seat sport Side-by-Side. For 2011, the family adds the RANGER RZR XP 900, a whole new class of Side x Side that continues to offer the ultimate combination of power, suspension and agility and takes it to the extreme.
Built for razor-sharp, Xtreme performance, the RANGER RZR XP 900 has a new 88 horsepower, 900 Twin, Electronic Fuel Injected (EFI) engine, a new 3-Link Trailing Arm Independent Rear Suspension (IRS) with 13-inches of ground clearance and 14-inches of travel, and is light weight with a low center of gravity for unmatched cornering. These features make the RANGER RZR XP 900 the only extreme performance Side x Side on the market.
“The RANGER RZR family delivers the ultimate combination of power, suspension and agility,” said Matt Homan , vice president and general manager of Polaris’ Off-Road Vehicles Division. “When we set out to design the RANGER RZR XP 900, we wanted to create a ground-breaking, high performance vehicle to complement our current, best-selling RANGER RZR line. The result is simply incredible.”
The ultimate combination of power, suspension and agility starts with power. At the heart of the RANGER RZR XP 900 is the all-new, 88 horsepower ProStar™ 900 Twin EFI engine that was built specifically for an extreme-performance Side x Side. The engine features Dual OverHead Cams (DOHC), four big valves per cylinder and a 180-degree crankshaft for balanced performance and fast throttle response for groundbreaking acceleration. The combination of 88 horsepower with the vehicle’s light weight provides acceleration that is 29-percent quicker than the next quickest Side x Side on the market.
To complement the potent power plant, the RANGER RZR XP 900 features an all-new, lightweight, compact and durable transmission, also designed specifically for extreme Side x Side performance. Efficiency has been maximized by eliminating all right angle drives to the rear axle resulting in less friction and more power delivered directly to the rear wheels. And, the simple and efficient design also provides a very quiet transmission.
In order to handle the massive power of the new engine and keep the ride smooth, Polaris designed the all-new, 3-Link Trailing Arm IRS. The 3-link design consists of two extra-long radius rods and a far forward-connecting trailing arm resulting in a strong, yet lightweight system. The RANGER RZR XP 900 also is outfitted with adjustable, premium 2-inch body Fox Podium X 2.0 shocks. Its monstrous 14-inches of terrain-absorbing rear travel and 13.5-inches of front travel soak up the rough stuff and deliver a smooth, precise ride, while its astounding 13-inches of ground clearance gives the machine the ability to tackle any obstacle in its way.
For razor-sharp agility, RANGER RZR XP 900 has no equal. Even with its incredible ground clearance, the unit still features a low center of gravity for the ultimate ride over rough terrain. The patented, engine-behind-the-seat design and rear weight bias deliver extreme, razor-sharp agility and performance, while the race-inspired rear suspension maximizes traction and power in the corners. To provide precise cornering, the suspension’s radius rods extend deep into the wheel hubs and feature an uneven link geometry that optimizes camber. Tires lean into the corner through the suspension travel, and plant more tire surface on the ground for maximum control. The trailing arms also minimize wheel scrub for superior straight-away power to help the driver stay true to line.
A premium vehicle needs premium features, and the RANGER RZR XP 900 has many. The machine features the industry’s first factory LED headlights that shine a high-intensity beam to turn night into day and throw light forward beyond conventional halogens. For ultimate stopping power, the RANGER RZR XP 900 has performance brake calipers and large diameter, ventilated rotors on all four wheels. To complement the new suspension, the RANGER RZR XP 900 is outfitted with completely adjustable Fox Podium X 2.0 shocks on all four wheels. The Fox Podium X 2.0 shocks have a 2-inch body with piggyback reservoirs that provide adjustable pre-load and compression dampening. For high performance riding, ITP 900 XCT tires provide a unique, directional lug pattern for exceptional cornering and straight-line traction capabilities. To maximize cooling capacity, the unit features a massive grill opening and a front air dam for improved air flow. For safety, the RANGER RZR XP 900 has a certified roll-over protective structure (ROPS).
The RANGER RZR XP 900 is offered in Indy Red and a White Lightening limited edition model, and will be available at Polaris dealerships in January. More than 70 PURE Polaris accessories, including cargo boxes, winches and protection also will be available at launch.
Polaris reserves the right to change specifications at any time without incurring obligations.
LIMITED EDITION RZR XP 900
The NEW XP 900 RZR Intake Set Up.
Customize Your Ride with Pure Polaris Accessories
For the launch of the RANGER RZR XP, PURE Polaris® has added over 10 product-specific accessories as well as 60+ current RANGER RZR® accessories will fit this vehicle. Pure Polaris accessories are easy to install, fit right and add custom style and performance to make driving more fun.
Key Accessories for RANGER RZR XP​
Bumpers/Guards
Pre-Runner Brushguards
• Provides protection for front and rear
• Available in Brushed Aluminum or Powder-Coated Steel
• Front integrates with any winch or plow system
• Easy to install
Underbody Skid Plate
• Ideal for serious trail and desert riders
• 0.125” aluminum for front two-thirds of bottom
• 0.1875” aluminum for rear one-third bottom
Front A-Arm Guards and Rear Trailing Arm Guard
• Added protection to A-Arms and Trailing Arm
• Strong, lightweight 0.125in/.3 cm Aluminum
Aluminum Rock Sliders
• Smart styling complements the sporty look of the vehicle
• Protects the sides and bottom of the vehicle from rocks, stumps and other off-road hazards
• Durable tube construction with a rust-resistant powder-coat finish
• Easy installation with pre-drilled mounting locations
Cargo Box
• Protects your gear while riding
• Attaches to bed in 10 seconds
• Rubber gasket keeps out dirt and water
• Lockable latches, heavy-duty hinges, side handles
Audio/Lights
SSV Works® Speaker System and Add-on Speaker
• Includes a radio and can use a radio ad its music source
• Includes two marine grade speakers
• Weatherproof to deliver outstanding performance in a wide range of off-road conditions
• Durable fiberglass housing for reliable performance
4 Light LED Bar
• Provides 1200 Lumens of extra light
• Has four 5-Watt LEDs and stylish durable cast aluminum housing
• Requires light harness (sold separately)
Roofs/Windshields/Panels
RZR XP Clear Poly Panel
• Clear polycarbonate, helps reduce dust swirl behind windshield
• Attaches to rear cab frame with p-clamps
• Works with all roof combinations
Aluminum Roof
• Durable, lightweight aluminum
• Easy to attach and remove from vehicle
RZR XP Rear Panel - Fiberglass
• Durable, fiberglass construction that can withstand aggressive driving
• Helps reduce dust swirl behind windshield
Winches
RZR XP Warn Winch 3.0 Kit
• Features Polaris exclusive mount plate
• Delivers an incredible 3,000 lb./ 1,360.8 kg rated pull
• Convenient handheld remote
• Includes roller fairlead, hook, and strap
• Integrates with all Polaris brushguard systems
Winch Kit Polaris 3.5
• Most powerful winch available for RANGER RZR
• 50’ (15.2 m) of .1875” synthetic rope, with a 3,500 lb. (1,587.6) rated pull
• Rugged 1.2 hp motor, sealed for extreme conditions
• Includes handheld remote, roller fairlead, hook, strap
RZR XP TPO Kit
• Kit includes rear fenders, hood, access panel
• Panels are ready to be painted
RANGER RZR XP and RANGER RZR S Cover
• Made of UV stable material to protect from fading
• Ratchet strap system on the bottom to secure the cover
• Designed with pockets to work with all bumper systems, roofs, and box accessories excluding the spare tire holder, and gun scabbard
• Forward trailering only
<object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/KPd3vNEey1s?fs=1&amp;hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/KPd3vNEey1s?fs=1&amp;hl=en_US" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>
<object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/zrc-wqg20Bo?fs=1&amp;hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/zrc-wqg20Bo?fs=1&amp;hl=en_US" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>​
NEW! 88 HP 900 TWIN EFI ENGINE
Specifically built for an extreme performance Side x Side. The Polaris ProStar™ 900 features industry-leading 88 HP, Dual OverHead Cams (DOHC), large valves for high RPM power and 180 degree crank shaft for balanced performance. This delivers fast throttle response, groundbreaking power and revolutionary acceleration.
XTREME PERFORMANCE POWER to WEIGHT
It's 29% quicker than the next closest competitor. This revolutionary acceleration is made possible by the 88 HP lightweight engine and total vehicle weight combined with big-time power to the ground. The result is loads of torque to all four wheels and unsurpassed off-road acceleration.
NEW! LIGHTWEIGHT, COMPACT TRANSMISSION
Specifically built to optimize power of the new Polaris ProStar™ 900 engine, its high-torque capacity delivers superior performance and handling. This means more power to the ground, less driveline noise and lighter weight. The innovative lightweight design features a helical cut final drive with optimized gear geometry to maximize efficience
NEW! 3-LINK TRAILING ARM LONG TRAVEL IRS
We designed the all-new 3-Link Trailing Arm IRS to handle all that massive power and keep the ride smooth. The 3-Link design consists of two extra-long radius rods and a far forward-connecting trailing arm resulting in a strong yet lightweight system
NEW! NEVER-BEFORE-SEEN TRAVEL & GROUND CLEARANCE
The new 3-Link Trailing Arm IRS, paired with premium Fox Shocks, creates a monstrous 14" of terrain-absorbing rear travel. Match that with an astounding 13.5" of front travel and 13" of ground clearance and no comparison is required. Hands down, RANGER RZR XP™ owns the desert, the dunes and any wide open space
PREMIUM SHOCKS WITH FRONT DUAL A-ARM SUSPENSION
Standard on all 4 corners are premium Fox Podium X 2.0 Shocks with piggy-back reservoirs - compression and preload adjustable. Pair that with Dual-A-Arm front suspension with 13.5" of travel and it soaks up the rough stuff and delivers a smooth, precise ride every time
LOW CENTER OF GRAVITY
Even with 13" of ground clearance, RANGER RZR XP™ still has a class-leading low center of gravity for the ultimate ride through rough terrain. Its patented engine-behind-the-seat design and rear weight bias deliver extreme, razor-sharp agility and performance.
NEW! UNMATCHED CORNERING AND STRAIGHT-AWAY AGILITY
The new 3-Link race inspired rear suspension maximizes traction and power in corners and straightaways. Tires lean into the corner through the suspension travel, planting more tire surface on the ground to create positive tire camber for more control. The trailing arms also minimize wheel scrub for superior straightaway power, helping you stay true to your line
ON-DEMAND TRUE ALL-WHEEL DRIVE
True AWD gives you the ultimate grip to put that 88 HP to work in the corners, whoops and loose terrain. It’s the easiest to use and fastest responding on-demand system, automatically engaging all four wheels when you need more forward traction and reverting back to 2WD when you don’t. This means less wear and tear, easier steering, and maximizes power when you need it most
RANGER RZR XP™ 900STARTING AT: $15,999 U.S. MSRP
Engine Type
4-Stroke DOHC Twin Cylinder
Displacement
875cc
Fuel System
Electronic Fuel Injection
Cooling
Liquid
Transmission/Final Drive
Automatic PVT P/R/N/L/H; Shaft
Drive System
On-Demand True AWD/2WD
Front Suspension
Dual A-Arm Fox Podium X 2.0 (comp adjust/res.) 13.5" (34.3 cm) Travel
Rear Suspension
Trailing Arm Fox Podium X 2.0 (comp adjust/res.) 14" (35.6 cm) Travel
Front/Rear Brakes
4-Wheel Hydraulic Disc with Dual-Bore Front Calipers
Parking Brake Park in Transmission
Front Tires / Model
27 x 9-12; ITP 900 XCT
Rear Tires / Model
27 x 11-12; ITP 900 XCT
Wheels
Cast Aluminum
Wheelbase
81.4" (206.8 cm)
Dry Weight
1,190 lbs. (539.8 kg)
Overall Vehicle Size
(LxWxH) 108.4" x 64" x 73" (275.3 x 162.6 x 185.4 cm)
Ground Clearance
13" (33.0 cm)
Fuel Capacity
7.25 gal (27.4 L)
Bed Box Dimensions
(LxWxH) 23 x 38 x 10" (58.4 x 96.5 x 25.4 cm)
Box Capacity
N.A./300 lb (136.1 kg)
Payload Capacity
740 lb (335.6 kg)
Cargo System
Lock & Ride
Lighting
White LED, High/Low
Electronic Power Steering Not Equipped
Instrumentation
Digital Gauge, Speedometer, Odometer, Tachometer, Tripmeter, Hour Meter, Clock, Gear Indicator, Fuel Gauge, Hi-Temp/Low-Batt Lights, Coolant Temp, DC Outlet
COMFORTABLE ERGONOMICS
Everyone rides in comfort, thanks to adjustable and interchangeable bucket seats, plus the adjustable front passenger handrail and full rear passenger handrail. Comfortable driver operation is enhanced by tilt steering with the highest range of motion (10").
PREMIUM SHOCK PACKAGE
Premium Fox Podium X 2.0 Shocks feature piggyback reservoir, adjustable preload and compression dampening.
FRONT TRAVEL and HIGHEST GROUND CLEARANCE
Dual-A-Arm front suspension with 13.5" of travel soaks up the rough stuff. Match that with an astounding 13” of ground clearance and no comparison is required. Hands down, RANGER RZR XP™ owns the desert, the dunes and any wide open space.
NEW! Exclusive ITP® Tires Standard
Exclusive ITP 900 XCT TIRES – Standard on RANGER RZR XP™, the unique directional lug pattern provides exceptional cornering and straight-line traction capabilities.
NEW! GLOVE BOX STORAGE
Passenger-side glove box has 3 gallons of space for convenient, water-resistant storage.
We designed the all-new 3-Link Trailing Arm IRS to handle all that massive power and keep the ride smooth. The 3-Link design consists of two extra-long radius rods and a far forward-connecting trailing arm resulting in a strong yet lightweight system.
Check out UTVGuide's XP 900 Release Page
Polaris RZR 900 XP - UTV Guide
racemx587
Mar 28, 2009
141
4
That thing is sweet! Too bad I just put a new cage and long travel on mine haha
18,569
1,368
113
I got more info coming...I am picking through our media FTP site as we type...keep hanging around...I will keep posting pics and info as I pull it down...I had to wait for most of this stuff too. I can say now that we (UTVUnderground & UTVGuide.Net ) will be geting to drive the new 900 in a couple weeks for a full report!!!
chad549
20
wonder if we will see one in parker next week ?
hope to have mine in the shop in a few weeks.
Desert Toyz Cory S
DeSeRt ToYz RhInO - UTVUnderground Approved
Aug 23, 2009
125
9
58
Nice machine! Looks like Polaris is playing catch up to Can-Am Commander! Like I said "Catch me if you can"!:D
RHINOdan
RHINOdonkey
Oct 11, 2009
1,060
39
Dude that thing looks bad ass! The 3 link trailin' arms system and 88 HP V-twin is a great upgrade for 2011! :)
I have this great feelin' we are gonna see alot of RZRs for sale and even other UTVs. Peeps are gonna want to jump on one of these bad boys! BTW Anyone wanna buy a Rhino wit a custom green paint job? :rolleyes::p
