Squadron Specifications:
3600 Lumens
340 grams, 0.75 pounds
Measures 3†x 3†x 2.76 Deep
Uses four T6 Bin Cree XML LEDs at 5000K
44 watts power draw (3.1 amps at 12 volts, 1.6 amps at 24 volts)
11-32 Volts Power Input
92% Electronic Driver Efficiency
Available in three configurations, Spot, Driving and Wide using precision in house designed optics.
Uses active Thermal Management to maintain LED temperature within defined operating limits. Automatically reduces LED power when there is inadequate airflow to maintain proper operating temperatures.
Single Layer Solid Core Copper Circuit Boards with copper vias and high performance thermal prepreg give industry best thermal transfer; important for getting the highest performance and long life from high power LED’s.
Estimated LED life: 25,000 hours
Billet Machined housing, hard coated polycarbonate lens, stainless steel fasteners and mounts.
IP68 Water Proof, Submersible to 3 meters
Lifetime Warranty
3600 Lumens
Lifetime Warranty
