Can-Am TurnKey UTV Can Am Commander Seat Belt Sensor Delete Kit
18,569
1,368
113
North County San Diego
www.utvunderground.com
This item is a must for those who install after market seat belts or roll cages on their Commander. This sensor delete allows you to bypass the factory seat belt sensor on your Can Am Commander. Without this part and using non-factory safety restraints the vehicle is limited to 10 MPH.
This part installs in under 5 minutes and can be removed just as easily. Do not risk cutting into the factory wiring harness and potentially losing your warranty or causing damage to your vehicle. This part is an easy direct plug in to the factory harness. Harness is built using identical connectors used by the factory and hand assembled in the U.S.A.
MSRP: $24.95
TurnKey UTV
