newbie seeking advice
Discussion in 'Introduce Yourself' started by maha, May 10, 2010.
  1. maha
    maha New Member
    May 10, 2010
    Hello All,
    I'm new to the UTV's. Been eyeballing the Rhino for the last year, having hard time convincing the wife on why I need one of these.. :D
    Looking for some advice... I live in the S.F. Bay Area. Have a cabin in Lake Tahoe (6500-7000ft in elevation). I read the new FI ones are better for ridding in different altitudes. Of course the older Rhino's (<2008?) are not FI..
    Of course, I don't have $12,000 to spend on a brand new one... any suggestions?
  2. MAGNUM
    MAGNUM Magnum Off Road - Official UTVUnderground Sponsor
    Apr 5, 2010
    Welcome to the site good luck!!
  3. DUNE DUMMY 29
    DUNE DUMMY 29 OG Sticker Man - UTVUnderground La Familia
    Feb 28, 2009
    EL CENTRO
    2008 OR NEWER ARE 700 CC FUEL INJECTED. THERE ARE SOME FOR SALE ON THIS SITE AS WELL AS OTHER SITES.
  4. maha
    maha New Member
    May 10, 2010
    How difficult is it to re-jet the carburetor (pre-2008 models) at different altitudes? What happens if I just leave it at the factory setting? I just lose power right? won't hurt anything?
  5. DUNE DUMMY 29
    Feb 28, 2009
    EL CENTRO
    I HAVE A 660 WITH A CARB. I RIDE IN THE MOUNTAINS SOUTH OF SAN DIEGO ALL SUMMER LONG. I ALSO HAVE RIDDEN @ LAKE SILVERWOOD (BY LAKE ARROWHEAD) & I HAVE HAD NO PROBLEMS WITH THE CARB. I HAVE A K&N FILTER WITH AN OUTERWEAR & A DRAGONFIRE RACING CDI.
  6. maha
    maha New Member
    May 10, 2010
    I have a cabin in North Lake Tahoe. Trails there are in the 7000-9000ft range... then when I get home to the trails in the SF Bay Area, it's sea level.
  7. family wagon
    family wagon White Knuckled - UTVUnderground Approved
    Jan 29, 2009
    Riverside
    Welcome to the underground ! If you plan on getting a 660 it is not that bad to rejet. I would get a wide band A/F gauge which will set you back about 200 and I would change the jets when you are in SF or Tahoe. If you jet your rhino for sea level then go to tahoe it will run shitty but shouldn't hurt the motor. If you jet for tahoe and then drive it in SF it will be SUPER lean which will kill the motor !!!! Check out craigslist you should be able to find something cheap and you might want to lean towards FI if you don't want to worry about jetting
  8. maha
    maha New Member
    May 10, 2010
    thanks for the advice.
  9. mssandslinger
    mssandslinger Rhino Parts & Performance - Official UTVUndergroun
    Oct 18, 2009
    AZ
    Welcome! If you go with a 660 later on if you want to make motor changes down the road its going to be much easier. The down fall is having to re-jet, (which isn't hard at all really) so i would go with a 660. And they are cheaper then the 700. im sure you can find a nice used 660 online that's all built up.
  10. RHINOdan
    RHINOdan RHINOdonkey
    Oct 11, 2009
    Welcome to UTVUG! Good luck on your find!
  11. family wagon
    Jan 29, 2009
    Riverside
    No prob mang....I have a 660 and just rejet and like stated above it is EASY
  12. greengoloco
    greengoloco greengoloco
    Mar 3, 2009
    Flagstaff AZ
    I have a 07 660 for sale. Real clean only 460 miles. I asking $7000.00 obo. I ride at about 7000 ft elevation and at sea level with no problems with jetting.
  13. maha
    maha New Member
    May 10, 2010
    PM me..
Share This Page
