Welcome to our new How-to video series from UTVUnderground where the Pro’s show you how easy it is to do-it-yourself and fix your UTV.
Blown belts are one of the most common mechanical issues with UTV’s. The main reason belts fail is because of heat. If you push the belt system too far by running it above the recommended temperature it will fail. Now with the new belt temp sensor form rugged routes you can monitor your belt temperature and spend less time fixing your UTV and more time riding with your friends! watch multi-time off-road champion Mike Cafro show you how easy it is to install and connect to your Lowrance GPS system the rugged routes belt temp sensor to your UTV. Mike shows you how to install your rugged routes step by step as well as what tools you will need to make your install easier.
PURCHASE INFO: CLICK HERE
For full review article click on the link below:
