SPEED UTV – STADIUM SUPER TRUCK CONNECTION
Stadium Super Trucks will be racing this weekend at Road America. Tune in to SST Social media to watch the races live
Will fit 35’s
Will fit 32’s only
Questions
There will be three mounting locations for the spare. Two that allow the tailgate to close and one that will be out the back of the bed. The option that has the tire out the back can be used both with and without the tailgate on. This option will leave the tailgate secure in the down position if it is left on
We will be leaving half windshields to the aftermarket. We will only be selling the full glass windshields directly.
To get the power benefit of the Speed Key, E85 will need to be used. On the other hand, the Speed Key removes the top speed limiter, so there will be some benefit to running it all the time if desired.
Configurator
Accessories
Speed UTV OEM factory standard universal seat heater
PTC technology delivers major performance, safety & reliability benefits Self-Regulating Temperature
Faster-To-Ideal Temperature
Water resistant connectors and switch
Includes: This is for Quantity 1 Seats. Please order correct quantity of heaters for your vehicles. Quantity 1 must be ordered per seat. Pricing does not include 1 hour of install time.
1 – 12”x9.3” Heating Pad
1 – 17.3” Pad Extension Cable
1 – Panel Round On/Off switch, and all required hardware
Your Speed UTV motor, transmission and differential comes with standard brake in oil. This is not a synthetic oil, and needs to be run for the first 250 miles to properly brake in your Engine, Transmission and Differential. You must change your oil at the 200-250 mile brake in period to the recommended Speed synthetic oils. The transmission and differential use a proprietary 80/250 that was created specifically for the demands the high HP and 4WD will create on the internal components. Your factory and extended warranty is VOID if the 80/250 Speed Gear Oil is not run in the transmission and differential.
This kit includes.
4 Quarts Speed VP 10/50 Synthetic 2 Quarts Speed VP 80/250 Gear Oil 1 Speed Oil Filter
1 Speed Air Filter
1 Speed Factory CVT Belt
RATCHET TIE-DOWN
Heavy-duty holding strength
Built-in soft loop protects vehicle from scratches U 2 in. X 8 ft. Snap hook ends
– Adjustable axle straps on one end
– Sold individually
– UNIVERSAL
Speed Key Covered
Event Based Warranty Support : Glamis: Thanksgiving and New Year’s, Moab: Rally on the Rock, Dune Fest Oregon, King Of the Hammers, Idaho UTV Invasion Racer Pit Support BITD and SCORE (Vehicle entered in race voids warranty, full pit support)
Warranty Service and Repair Service Labor is FREE at all Speed Events listed in your warranty agreement.
NO Preventive maintenance done at events Warranty can be done by any Speed Authorized Dealer
CENTER MIRROR KIT
Wide angle of view for great visibility U Ball-and-socket joint allows for infinite adjustability
Lightweight, impact-resistant housing Billet aluminum clamps
Speed UTV, PCI and Rugged Radios have partnered together to make your buying and installation of your Speed UTV Intercom, Radio, and Dash Plate the simplest and cleanest in the power sports industry.
The kit comes pre assembled as show in the images. The Dash Plate is not just wired for the radio and intercom, but it is also pre wired for your helmet connection and car to car: push to talk. A first in the industry for installation, we have reduced the instal time from 4 hours to 30 minutes. Adding ease of use to the consumer, there are no additional wires to run through your car keeping everything clean and secure.
Pricing does not include .5 hour install
SPEED 5ft LED Whip/Flag. Let em’ know you’re coming!
The Speed Trail kit was designed to make sure any incidents on the trail don’t stop your ride, weekend or vacation. Flat tires happen, rocks and tress have a way of jumping out at you, and rear CV boots and axles don’t last forever. No before you go, and go prepared. The Speed Trail Kit includes:
Speed Wheel and Tire (All Speed wheel options available)
Speed C02 Jack
Speed Tow StrapSpeed Tie Rod (Quantity 1). It will fit left or right side
Speed Rear Axle (Quantity 1) it will fit left or right side
Speed UTV Factory CVT Belt: Fits All Speed UTV Models.
Speed spare wheel and tire
The Speed Co2 operated jack is a fast and lightweight jack that easily mounts to the roll cage. It utilizes 20-25 gram Co2 canisters that can be found at any bicycle store or on line. Powdered coated Black Stainless Steel construction keeps it looking new for years.
Features:
– Durable Stainless Steel and precision Aluminum construction. Over 2′ of adjustable lift height.
– Simple and intuitive Co2 Regulator controller. Compact design can be easily mounted to roll cage. Weighs 5.6 LBS.
Speed UTV Factory Bluetooth Stereo System: Included 4 120W Speaker, 10 Inch 500 Watt Sub, Speed UTV MP5 Player, Water Proof Amp.
- Waterproof UTV mp5 player
- 3 inch TFT screen high performance
- FM/AM radio
- USB port
- AUX in
- Front/Rear RCA out
- Subwoofer Output
- USB Video Input
- Rear camera input
- 4X50watts max power
- Bluetooth for audio streaming
- ASTM B117
- ASTM D4329
- Waterproof level:IP66
- Two pairs 120 Watt waterproof speaker with led light one pc 10inch subwoofer 500watt Waterproof Subwoofer
- Water Proof Amp InputCurrent:2×250w+4x200w@40 ohm
Speed UTV Cargo Box Storage: Storage box fits in factory bed with factory spare tire. Spare Tire and Cargo boxes have multiple configurations. Quantity 1 of either Crescent Box or Rectangle Box is shipped with each order.
The Speed Cooler was built for the off road environment – It is impact resistance durable and all day long ice retention. It is the perfect multi-purpose cooler and can do double duty as a work bench, non-slip step stool, or be tied down for the long days in the desert.
Speed Cooler comes in two sizes: Speed 45 and Speed 110
The Speed Race Case. The last tool you will ever need for your Speed UTV
Speed UTV Bead Lock Wheel
The two Piece Beadlock Wheel, can be ordered in either the Original (OG) RG wheel or the new 14 Spoke in either Powder Coated Black or Polished.
*Price is for 1 wheel
This is the original equipment tire that comes on all Speed UTV’s. It is a 32.5×10.15 and has the Speed Logo Tread Pattern. Designed as an all terrain 8 ply tire.
The same tire we race with is available to the customer. The ultimate in traction, performance and control.
The SPEED window net was designed to match the contour of the factory cage. The window frame and net are one piece and open as a complete assembly. They frames are both SCORE and BITD legal, and are a valuable addition to any vehicle. Driver and Passenger window nets are shipped with each order, with all mounting brackets, hardware and latching system.
- 1 IN. X 6 FT. SOFT LOOP TIE-DOWN (PAIR)
- 1 in. X 6 ft. cam buckle tie-down with soft loop
- Protects vehicle from scratches
- Cam buckle system offers quick-release functionality and smooth operation
- Sold in pairs UNIVERSAL
FIVE-POINT SEAT BELT HARNESS
- Universal 5 point latch and link seat belt for all vehicles
- Adjustable lap/sternum strap and padded shoulder straps with 2-3in.-wide webbing
Speed TOW STRAP 2 inch by 20 feet and Shackle
Be the Boss and take control of your air with the M3 Big Boss Pack complete with M3 Pumper, Variable Air Speed Controller and (2) pumper hoses.
The all-new M3 (MAC3.2) takes helmet air pressure to a new level. With the constant demand for more air flow in pumper style helmets, the M3 builds pressure and forces high volume air at a much higher rate of speed. Using a special built high static pressure fan the M3 produces 5 times the pressure and more volume than any other helmet pumper available!
Built from lightweight carbon fiber and 6061 billet aluminum the M3 is a featherweight at only 1.6 pounds. Small, compact and easy to mount with our exclusive half clamp bar mounts available in most tubing sizes.
Eliminate the dust with the purpose-built washable dry media filter with Outerwear particulate wrap. Run the entire race with one filter then simply wash in water so you’re ready for the next event. No more losing air because of a clogged filter!
Matched with our VSC (Variable Speed Controller) the M3 can be turned down for staging then instantly turned up for high-pressure ventilation. The VSC pulse control precisely adjusts the amount of air entering the helmet.
From start to finish the M3 is built to race. High pressure, high volume, lightweight construction, micron air filtering system, and waterproof connectors make the M3 the ultimate in helmet pumper systems. Keep cool and breathe clear with the new powerful M3 Helmet Pumper System from Rugged Radios!
THE NEW PYROCELL CELLS UTILIZE ULTRA DURABLE DOUBLE COATED URETHANE FABRIC BLADDERS FIA FT3 APPROVED WITH A 5 YEAR WARRANTY. APPROVED FOR ALL MAJOR RACING ASSOCIATIONS. COMES WITH FULL TIG WELDED ALUMINUM CONTAINER. (CELLS CONTAINERS ARE .080”) FUEL CELLS ARE DESIGNED TO FIT UNDER PASSENGER SEAT AND ARE 23 GALLONS. FUEL RANGE HAS INCREASED TO OVER 200 MILES. FUEL CELL INCLUDES HOLLEY HYDRAMAT.
Speed introduces the new dual functioning “A” pillar LED driving light and side mirror. Adding both style and functionality to your SXS, Speed has integrated a forward driving light into our side mirrors. A direct bolt on to your factory cage.
Hose Only
Pumper system and helmet are not included.
Speed Race Case was designed to be a traveling tool box. Every tool you need to work on your race car or UTV.
Heat & Sound Proofing Kit.
Get the best in under vehicle protection with Speed UTV full skid plate set. Made from 1/2′′ high density UMHW polymer, these plastic skids absorb the shock and impact to the bottom of the vehicle. UMHW does not dent or rust and are lighter than traditional metal skids. We have strategically placed drain holes to allow dirt and debris to be wash out off the skid plate – you no longer have to remove your skids to clean the rocks and dirt from the belly your vehicle. The Speed UTV Skid Plates are easy to install. The skids have jointed sections that cover the full length and breadth of the vehicle, including the front and rear differential. Mounting hardware and instructions included.
Get the best in under vehicle protection with Speed UTV Racer rear skid plate. Made from 1/2′′ high density UMHW polymer, these plastic skids absorb the shock and impact to the bottom of the vehicle. UMHW does not dent or rust and are lighter than traditional metal skids. We have strategically placed drain holes to allow dirt and debris to be wash out off the skid plate – you no longer have to remove your skids to clean the rocks and dirt from the belly your vehicle. The Speed UTV Skid Plates are easy to install. Mounting hardware and instructions included.
SPEED FIRE EXTINGUISHER WITH QUICK-RELEASE BRACKETS
- Lightweight
- Rattle-free design
- Billet aluminum machined mounts Single pin release
In offroad racing bumping into the other competitors is part of the game so protect your SPEED UTV with our Speed Rear PreRunner Bumper. It mounts onto your stock production mounts easily and you can wrap a tow strap around it if you need to, as well.
This is our Speed Front PreRunner Bumper. It’s very low-profile on the chassis and it mounts onto your stock front bumper mounts. It also doubles as a front tow hook.
The Speed Roof was designed to create positive pressure in the cab while running a full or half windshield. The Speed Roof fits with the OE windshield and creates positive pressure from the forward facing roof vent. No more dust or exhaust sucked into the cab from the negative pressure created by a full windshield.
Speed 50 Inch Curved Light Bar
- Kit Comes with Wildcat XX mounting brackets
- Specifications 50” Curved light Bar
- 50′′ | 17.1A | 288W | 25920 Lumens 96pcs* 3 watt* high intensity
- OSRAM Led’s. Beam Pattern: Spot (8°).
- Current Draw: 12V/17.1A,24V/8.5A Lux@10m: 320lx
- Operating voltage: 10-30V DC. Waterproof rate: IP67.
- Body Color: Black.
- Color Temperature: 6000K.
- Housing material: Die-cast aluminum housing. Polycarbonate Lens material: PC.
- Mounting bracket: Die-cast Aluminum. Electronics: Integrated-Epoxy
- Encapsulated. Operating Temperature: -40 ̊C to +60 ̊C. Protections: Reverse Polarity.
- 30000 hours above life time.
- Weight: 13.6 LB.
- Tab to Tab 50 1/8′′
- 50 1/8′′ x 3 1/16′′ x 5 7/8′′
- Limited Lifetime Warranty
